Disables MSDP on a virtual router.
| vrname | Specifies the name of the virtual router on which MSDP is being enabled or disabled. If a name is not specified, it is extracted from the current CLI context. |
MSDP is disabled by default.
Use this command to disable MSDP on a virtual router.
The following command disables MSDP on a virtual router:
disable msdp
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.ature-link-22.1"/>
